81 - 100 of 184 Posts
Discussion starter · #81 ·
Thank you!
Also I researched the lower pan sealant the last time I did this. According to Suzuki, they never used sealant on the lower pan. Just a gasket. Felpro recommends same. That's what I did on my LT and I haven't had any problems.
I use Ultra Gray too. Suzuki recommends a 2nd sealant, black, for some of the corners. There's a TSB on that in Max's stash.
Now my oil pans are all sealed up, with new O rings on the pickup tube. Yesterday I installed a new #1 timing tensioner, new water pump and several new guides. I got a new CPK sensor which is a lessons-learned from my prior install.
I'll be sealing up the timing cover tomorrow.
Reactions: skills4lou
I can confirm that on my XL7 the oil pan does not have the rubber plug. My guess is someone wanted to look inside without pulling the pan, so they drilled out an inspection port and plugged it afterwards.
I have two unused Fel-Pro lower oil pan gaskets left over. I didn't use them because my car did not come from the factory with a lower oil pan gasket. Here a link to a past discussion: Oil Pan Replacement - Gasket or No gasket?
Now my oil pans are all sealed up... I'll be sealing up the timing cover tomorrow.
Don't the oil pans and valve covers go on after the timing cover is installed?
Discussion starter · #84 ·
Ok I had it backwards, the factory used sealant and no gasket. My 01 Chevy service manual at vol. 2 p. 6-571 says the same thing.
However when I contacted Felpro, they recommended no sealant with this particular gasket. So that's what I did.
On the order of assembly, you tell me. Here's a snapshot of the Chevy manual. From what I can tell, it's organized by first the sequence of disassembly, followed by the sequence of assembly. They have you do the pans first.
I studied it. It'll work either way. I'll do the valve covers last.
When I replaced my water pump I removed the front cover but did not remove the oil pans. I was able to get it back together without leaking so you are correct that the front cover can be put on after the oil pans but here's the rub. The front cover has two alignment pins so you can't rest the front cover on the lip of the oil pan and tilt it into place. It has to slide straight in. And that sliding motion creates a wiping action that scrapes off the sealant. I don't know if the table of contents is a reliable guide for the order of disassembly. Here is an abbreviated list of the steps to remove the front cover from the Tracker factory service manual.
Installation is the list in reverse order.
Discussion starter · #86 ·
You're probably right. I know the sliding action you're referring to. I wasn't ready for the cover. Maybe I jumped the gun.
But there's one thing I know for sure. That I'm not taking that pan off to redo it.
Discussion starter · #88 ·
Ok quick update on this project and a question for you XL7 experts.
I spent the last couple days on the final touches to the 2.7 and getting the Tracker ready. I also reread this entire post, to make sure I've covered all issues.
Appears I may not have.
When I reread the auszookers post, I noticed for the first time that "oldschool" says the input shaft from the Tracker's auto trans won't fit the 2.7 crankshaft. Or torque converter, I'm not sure which.
Does anyone who has done this swap into a vehicle with auto trans know for sure?
Maybe I'm missing something but isn't this as simple as pull the torque converter out of the transmission and place it against the flexplate and see if the bolt holes line up?
If it helps any, the torque converter for a 2.7 XL-7 (01~03) is 22700-67D30 and the 2.5 GV (01~03) uses the same part number.
If the post below is what you're referring to ...
oldschool said:
If its auto then they are 99% the same, the bloody out put shaft is larger on the XL7. (and also the TC input to match)
I put a GV auto into an 02 XL7 and had to swap the OP shafts over.
He appears to be referring to a transmission swap, not an engine swap, and it's the transmission output shaft that is larger and the TC input will be the transfer case input shaft.
Discussion starter · #90 ·
My donor 2.7 is a 2004 but thanks for the tip and I might try doing that. Didn't know you can pull out a torque converter.
I'm not very familiar with the workings of transmissions I'm afraid. You're right about his post and input v output shaft. But I wasn't sure if by "TC" he meant transfer case or torque converter. So I wanted to nail that whole thing down.
I hope you're right and it is that simple. We'll know for sure in a couple of hours
Thanks again for your help.
Discussion starter · #91 ·
Here's the 2.7 engine, ready to go.
I used the Tracker engine-to-body mount brackets because apparently that's important.
I also decided to go with the XL7 valve covers with the screw type PCV valve. Because someone said I should match the PCV valve with the engine it was designed for. Otherwise the covers are identical.
I'll summarize all these interchange issues later.
My GM service manual for the 01 Tracker H25a specifies a specific GM "sealant" for the torque converter bolts. I triple checked, and the equivalent product is, if you can believe it, red loctite. Despite my concerns, I went with it.
I also used the black Permatex ultra black on specific corners of the timing cover and valve covers. The GM manual didn't call for it, but the more recent Suzuki TSB does. So I went with that.
Discussion starter · #92 ·
When I installed my rear main seal, the face of my new seal ended up being about 2-3mm deeper than flush. I couldn't pull it back out without damaging it. It seemed like there was still plenty of mating surface.
Anybody familiar with this seal and how it's supposed to go in? My manual just says "use the install tool" which sets the right depth.
Here is a comparison pic of my factory installed rear main, if that helps.
Discussion starter · #94 ·
Mines just a hair deeper, I think it'll be ok.
Thanks for that.
As long as there's no oil gallery it can obstruct that supplies, or drains the rear bearing.
Discussion starter · #96 ·
My seal is maybe 1mm deeper. I studied the situation on the install. I don't think it's blocking anything, thanks.
HOWEVER. The 2.7 engine did NOT go in, after two attempts. We got it on the studs but it reached refusal about 3/4" shy of seating all the way in.
I'm not concerned yet. The torque converter pulled forward on removal of the 2.5. I believe it's just not seated correctly. We have a rain delay. I'll try again when the weather clears.
Reactions: 2013GV
See these two threads. The engine is a different Zuk engine but the oil seal tools and technique appear similar to the V-6.
Make sure the torque converter is fully seated on the pump drive tags in the transmission, measure from bell housing on engine to flexi plate mounting face, torque converter mounting points should be in the transmission by about 10 mm more than that measurement ( measure from transmission bell housing face to torque converter) that gives required clearance for installation, once bell housing faces meet, you then slide converter forward to meet flexi plate
To get it to seat, me being a right handed person, I do it this way....
Support converter by snout with left hand, and use left hand yo apply slight rearwards pressure into the transmission. Gently jiggle the converter with left hand, rotate with right hand to get drive dogs to line up, and splines if they have also become dislodged. 2 tags, 180 depress apart so you may need to rotate either way up to 1/2 a turn will suddenly go in about 10 to 20 mm when they engage
And further rotate the torque convertor while advancing it in, for the oil pump drive tangs to engage / seat. Two stops on the way in other words.
3 in total if converter has been out, input shaft splines, stator splines and oil pump drive dogs.
Guaranteed to cause frustration for a first timer.
