'97 Sidekick Sport JLX, 1.8l DOC, 4-speed autotrans, 4x4. Idle speed control valve totally ineffective. Putting tranny in gear slows idle 150 rpm or so. Turning A/C compressor on lowers it another 150 and it is close to stalling.
4 shops have looked at it and played with it for 3 months. The IAC valve has been declared "bad" three times. Three were aftermarket of which 2 were returned to the mfg. It now has a new factory IAC and a new aftermarket MAF sensor. The throttle body has been cleaned including the manual idle needle passages. (That area was full of gunk). Nothing has changed.
There is a service bulletin TS-4-29-01-098 which talks about a programming error or fault in that system control. Does anyone know about that Bulletin and what is recommended.
The last shop which put the new IAC and MAF in said, "the computer and valve are working but the loop won't close" which I interpret as meaning that the computer is not recognizing the need for more air (Maybe no RPM input?)
The mechanic that has it now says his diagnostic equipment doesn't go back before 2000 models. Can anyone help me lay out a diagnostic plan? I have a scope which I have used on the connection from the computer to the IAC. before the valve was last replaced, I saw nothing but noise. Don't know what it shows now. I think I'm right in expecting to see 12v. square pulses.
