Thanks Ken,
I'm in Australia. I've read through this forums feeds and attempted a most of the links, perhaps I'm not using the correct updates or not waiting long enough?
Do you know of the correct update for vehicles imported to Australia?
Current status, I'm looking at buying this:
Grundig GX-3800 unboxing PLUS Review CarPlay Android Auto Stinger Electronics by @carstereochick - YouTube
Cheers,
Shell
Hello.
You need a firmware version starting 17xx for your region (18xx is for European models)
What make and model is your phone, and which version of Android is it running (9, 10, 11, 12) - some phones by OPPO and realme have had a whole bunch of issues with AA on Android 11.
Trying first with your current firmware, have you paired your phone with the SLDA for Bluetooth, does it work ok (calls, music etc)
Have you installed the most recent release of Android Auto on your phone?
Do you have a DECENT quality usb cable to plug the phone into the car with - any issues at all with quality or condition of cable will bugger the job up for sure.
To get Android Auto set up on mine I had to:
Install Android Auto app on phone
Pair phone to headunit first using Bluetooth.
Then with the SLDA turned on and phone connected on Bluetooth, connect the usb cable to complete the setup.
Allow permissions on the phone when it asks to access things like contacts, call history etc, etc.
You will need to be parked with handbrake on to do the Android Auto setup (to stop crazy people trying to do it while driving I guess).
On my Oneplus 6 (on Android 9) I also set the default usb mode to file transfer.
To do the fw update you will need the download linked on post 90 of this thread, and then follow the instructions quoted in post 92 to extract the files properly and then initiate the update - I used USB flash drive for mine without issue, but others have only had success using SD card.
You should only have either a usb stick or SD card connected - remove any device from the connection that you aren't using (Inc map SD card)
I've not come across anyone who has suffered catastrophe doing the update, but it is totally at your own choice to proceed (if it goes belly up, as far as I know, the SLDA has a fall back firmware partition to recover from, but you may need to leave it turned off for an hour or two for it to recover)
