Security problem with keyfob
274 views 2 replies 3 participants last post by  LMP
I have a 2018 s Cross that when I lock all doors with key fob they all lock ok but when I press key fob to open the doors only 3 will open, one of the rear doors will not open. Can’t work out if its a micro switch problem or an electrical fault
#2 ·
Let me ask you this question...
Where, in your mind would this microswitch be? On the keyfob there are two buttons, one locks all the doors, the other should unlock all the doors but only unlocks three ...
There are going to be a couple of different ways to lock & unlock all the doors without using the fob - there should be keylock on the outside of the driver's door and also a button or lever on the inside - what happens if you use those, do you get the same symptom, the same door not unlocking?
I'm going to guess, without any testing and as a matter of fact without ever seeing an S-Cross (they have never been sold here), that the problem occurs no matter which method you use and that suggests the problem is the lock actuator on that particular door.
#3 · (Edited)
