GV2 1.9ddis
23 views 2 replies 2 participants last post by  osjovoll
No compression after fixing snapped timing belt.
Changed all valves, head gasket, piston rings, cam sprocket. Timing belt is mounted correctly!
Can turn the engine with one finger, almost.
Whats wrong here?
I have changed the head gasket three times looking for the fault. I grinded valves against seats as you should and leak tested.
The equpiment i got for compression leak test through the glow plug hole only fits on cyl 1. The needle barely moves. I'd have to remove the injectors to get to read all of them. But i think they are all as bad.
I have tried to find any fault with the timing. But i just cant find anything.
The three marks on the belt are put on the three sprocket marks. As every youtube video tells me. The cam shaft cant be put wrong.
I have not tried starting-gas or pulling it with another car to get it going. Could this be worth trying?
