Can I use this relay in my geo metro 96 lsi
409 views 10 replies 4 participants last post by  fordem
omron g8h-ua-007401 31x5a12 c is this fuel pump replaceable with a
NAIS ACM33201 M08
Both 4 pin that match made in Japan
I don't have power at fuel pump but power going into relay but none being relayed
#11 ·
The proper repair is to find the fault and fix it, and in a previous reply I suggested that you might have a problem with the fuel pump ground - it's now up to you or someone who knows how to use a test lamp or test meter to confirm that diagnosis, which was based on statements you made, which seem to have been based on tests that might not have been correctly done.
Once it has been confirmed that the problem is a faulty ground, then the fault needs to be located and fixed.
