"96" suzuki baleno ignition timing marks g16b motor where are they
7K views 8 replies 5 participants last post by  fordem
hey guys could anyone please help me with this one
"96" suzuki baleno ignition timing marks g16b motor where are they ? looked everywhere even serched the net for hours all i can find are timeing belt marks
trying to put a timeing light on it to check it can anyone help cheers :)
#2 ·
Hello Toe,
Had a look in the manual I downloaded and it it looks there are some marks above the crankshaft pulley. I tried to insert a picture but it would not let me.
I cant remember where I found my manual. There is a definite procedure to it as well.
Hope this helps,
Karl
suzuki g16b ignition timing procedure
the procedure have something to do with the 4 diagnostic wires in the connector under the fuse panel in the engine bay ...
I read somewhere* joining two of those wire should do it
The connector is a 4 pin square plug with 4 wires one black , black/white ,brown and brown/white ..
The brown ones both measured 12.0v exactly
But sadly I bridged the wrong ones brown and black and blew some fuses
Lost power to everything and won't start
#4 ·
hey guys found it dident relise there was a second fuse pannel right up under the right hand dash tucked away there ...fuse blown ...new one shes all good now
would of been nece to find it before i spent a couple of hours chaseing engine bay wireing but it seems to be the way :rolleyes:
does any know what wich diagnostic wires i should have paper cliped given that specific moddle ?
#6 ·
Since you have a 1996 model it should have an OBD-II connector under the dash somewhere, there are no wires to short together to make the check engine light (CEL) flash, you will need to buy or borrow an OBD-II reader to read the codes in the computer.
It should look like this:
Shorting wires under the dash will result in (like what happened) blown fuses and/or fried parts, that only works on certain pre-OBD-II systems (1995 and older) so please don't try that on any car that is 1996 and newer.
But, glad you found the blown fuse I wish Suzuki had put the under the dash fuse box in a much more accessible location.
