I've read some of the previous posts about Sidekicks not starting and such. I found some of the information helpful but still not certain what's going on.
Initially it began as a slow start problem, turn the key and wait for a few seconds for it to make up it's mind that it was going to start. Then my stepson drove it to work one night & I got the call the next day that it wouldn't start at all. I figured it was something with the ignition switch itself (the key has become sticky when trying to turn). So I got the poor thing towed home.
I got to poking around & trying different things, then stuck my head under the dash & checked the fuses. Sure enough, the ig coil fuse was blown. So I replaced it, started the car & moved it with no problems. The next day, drove about half mile down the road & it blew again. So I replaced it to make it back home.
Since then, as soon as the key hits the "on" position, the fuse immediately blows. I have a new ignition switch, checked the coil & relay, the fuel pump & main relays, and I'm still lost.
Is there anything else that won't cost a small fortune or another way to eliminate possibilities?
