41 - 60 of 70 Posts
Discussion starter · #41 ·
Thanks. Interesting that this company began only in 2021, so the longevity of its engines is still to be determined. Only 7 reviews listed thus far, so it will be interesting to see how Jakesuzi’s experience is.
I did choose an outfit called Chongqing Xuancheng Import and Export that said 10 years in business and had very lengthy conversations with Larissa there. She was really enthusiastic and I did make the purchase but I had questions she couldn't answer and in the end I backed out and got a refund. I felt bad for her. I think now it was likely the exact motor I ended up with. I note that this engine block has heavier webbing at the main bearings and the cooling jackets are just like the 1.3 ...surrounding the cylinders almost completely . I take these to be positives. The liners appear the be recessed into the cylinder walls as viewed with the head off..or maybe just much thinner than my original 1.6 blocks...I'm not really sure on this. It will be interesting to see how this block casting method holds up!
Discussion starter · #44 ·
i think its 3 years in alibaba rather than just 3 years making engines :)
I am very interested in going with one of these Optimus G16B motors. I see from the pictures that the bellhousing hole near the starter is different. How did you deal with it?
k
Hello. I've come back here with an update... Many hours of negotiating and a couple of buys and refunds later this is what I did. Although Alibaba showed and still shows bare blocks for 1990's trackers ,sidekicks,Vitaras, Ecudos and any other iteration you prefer I was not able to locate any at all. I paid for a couple but when it came down to it I was refunded.. The refund process was seemless. In the end I bought the Optimus 1.6 16v version with what I will call the updated block casting process. The lady I dealt with was totally on the ball and answered any and all questions in a timely manner..even when she was on vacation! Now,I already bought stuff to put a stock 8v together for my 90 tin top so rather than keep on fishing for a sound high mileage block used , I converted the Optimus one...This included replacing the head,head gasket,pistons and rings,water pump,oil pan and timingbelt and gears.. The only issue at all was a different location for the lower power steering pump bracket bolt...it was bossed a little higher up so I just measured and drilled a new hole in the bracket. I mic'd the bores and the stock 8v pistons(new ones) were a perfect fit. Everything lined up including the lower crank cog...Now having said all that...the lower rear engine mount holes do not line up and they are not the same as a 1.3 . They are in between. I had lots of time to come up with a solution while I tracked the freighter coming to Vancouver. So now I have a brand new blockand stock stock bottom end. The only thing that isn't new is the head casting and I did not put seats and guides in that . I did put new rocker arms and shafts, new camshaft and seals,new valves and springs in it ...checked the guides and lapped the valves. The cam is the torquer version and I put a stainless header in it along with a new converter and resonator..I went 2 inch stainless all the way to the back. This block is well made imo .The only thing I found was a small piece of gasket in the pan. If anyone is interested in what I did with mounting situation I can post details...Flashed right up .
How is it running today?
Discussion starter · #48 ·
Discussion starter · #50 ·
they are all G13B , i.e. 1300 c.c. ...... you need G16B
regardless, the two in the center have oil sumps for transversal engine installation (suzuki swift), our cars are longitudinal
you need sumps like the 1st and last examples in that pdf.
see the difference?
Umm - "sumpwise" only the last example would be suitable for a Sidekick - the first example has the sump to the timing belt end of the engine, and that is actually for a transverse installation, the last example has the sump to the rear, which is how the Sidekick oil pan is - the two in the center are actually longitudinal mount, but tipped over at an angle so that they fit under the front seats, these are for the Carry/Every van line.
Discussion starter · #52 ·
right, sharp eye!
in any case, all engines there are 1300, so irrelevant (unless he wants to downsize from 1600 to 1300, dont think so....)
@jwoodward96 in short, you should search for a G16B engine with a sump configured as in the last picture,
that said, i have seen several swaps into our cars from swifts and balenos which have the "wrong" sump, all what people did was reuse their old sump and the oil pick up pipe.
good luck!
These are some strange looking oil pans, very interesting. I have read about those tipped over engines. This is the first time I have seen them. very, very interesting
I can't speak to the whole engine, but I put this head on 500 miles ago and it is performing with no issues.
Discussion starter · #55 ·
nice of you sharing and updating, important to know as parts get scarcer.... do you know the name of the factory making it?
regretfully i get this message, so cant even see the part
All I'm going to add here, is the list of vehicles they claim that head works on did not share the same cylinder head or even the valve train.
I can see at least three vehicles listed on which it will not work.
Discussion starter · #59 ·
well said!
but at least in this case we have someone actually confirming fit, just the way Bex likes it! :)
LOL…it’s always better to actually confirm fit, before it’s shipped to your door…..;)
41 - 60 of 70 Posts
