Status
Not open for further replies.
81 - 100 of 133 Posts
thx for the reply Larry!
I will check it in 4 min from now!!
BRB!
Oil level appears to be fine.
It makes a rattling sound...jumps all over the place in the RPM range kinda way.
last oil change was less than 3 months ago.
i really think its the time chain issue since all the cylinders are missfiring.
i hope im wrong.
If it is, what does that cost?
ball park?
I don't think it's chains.. You would have a P0008
After 3 months you should be down at least a quart or or 2..
The dipstick can be decieving.. Please check again very carefully..
Even add a quart and recheck.
I'm almost positive it's low..
Save
Yup should take care of everything
Save
You should be checking the oil after the engine rests for a bit..
Save
i just put in 2 qts. i need to run an internal engine clean thru it.
What do you recommend if indeed this is the resolution?
(I cant tell you how much I want you to be right on this!)
BTW - thanks much for your help.
I will let you know ASAP...
It's tough to get rid of sludge if it's there..
But for the next few oil changes, before you change the oil add a liter of automatic transmission fluid into the oil and run it hard for 10 minutes before dumping the oil..
Save
So i put a total of 1.75 quarts in it. not sure of the total amount in it.
took it for a spin around the block. MUCH improvment. Alot less hesitation.
But its still there to some degree.
So in the morning i will drain as much oil as i can.
refill with 5.5 qts and a new filter.
and i will report back as soon i have something to report!
I cant thank you enough for your help lumpylarry.
Awesome!!
Let me know how it turns out tomorrow..
Save
How'd it work out with the oil change?
Save
so i had an oil change this morning. drove away with new oil synthetic, filter, drove home no hesitation. Drove to cracker barrel to eat breakfast, hesitated alot.
i give up. i dont know what to do anymore.
5.5 quarts right?
Save
looks like it's time to take it to the dealer.
Save
If they can reproduce the hessitation, that would be a start. Worst case, there is a record the problem happening in the system.
Have you gone through all the maintenance items? Check the air filter for obstructions, etc.
Have all your bases covered before they come back and try to blame it on you (not saying that it will happen).
There is a TSB about transmission oil leak, the hessitation could be the clutches slipping.
Does the problem happens in the morning/afternoon, engine cold/warm etc. What I mean is, have you found a pattern?
Save
the closest pattern i have found is it does not hesitate when the engine is cold.
only does it around 40-55 mph
going to manual vs auto mode does not affect it.
does not do it under heavy to moderate acceleration.
thats all i got.
does not pop a check engine light
2008 Suzuki XL7 Timing Chain
I have a used XL7 just under 100k miles. I have had the check engine light on for awhile now. I got the code P0008 the first place I took it and they replaced an O2 sensor. It went off for about a day and came back on. Now I had a new garage look at it and they tried to desludge my oil and turned off the light, only for it to come back on. Have inspection due at the end of Sept and they said I need to have the timing chains replaced.
Any words of advice?
I noticed that some people used the GM chains because they match up and are cheaper, is this true?
Can they check anything else that may be causing this issue?
The car is one payment from payoff, so I would like to go w/out a payment for awhile, plus I like my car, so not planning on getting rid of it anytime soon. I would just hate to dump money into it to find out his isn't the real issue.
Thanks for any advice!
You need to replace 3 timing chains.
If you're already opening it up, it's recommended to also replace tensioners plus associated gaskets.
Save
Status
