Status
Not open for further replies.
41 - 60 of 73 Posts
wiskid,
I also thank you for posting this. I had this same issue a few years ago when it was still under a "warranty" period that was supposed to cover "everything". Of course when I went to pick it up that was one of the things in fine print that wasn't covered. Talk about high cost, when my bill was all said and done it was just over a thousand dollars. They got the supposed ok from my wife on a phone call to use BG products to clean the throttle body and whatever else, so that added to the gouging. I was so pissed off. Now if it happens again I will refer back to your instructions and try it myself.
I would've been furious. That is so much money! Hopefully you won't have to deal with it again. Anymore, it takes a lot for me to take a vehicle to the garage. I am willing to try anything before paying someone to do it for me. ;)
I am getting this code also. I am researching the gaskets needed for the job. I have found the egr gaskets, but can't find the 2 gaskets on the manifold at each end. They are round with 3 holes. Any ideas?
Save
I was able to reuse all the gaskets. But if you need new ones, RockAuto has them.
It is under the EGR gasket category in Emissions. It is the gasket for "pipe" For a 2007 2.7L Grand Vitara, it is Fel-Pro part #71026. Cost in $1.90 each.
More Information for FEL-PRO 71026
Hope this helps. ;)
I just checked and it seems the EGR systems are the same on the following:
2002-2006 XL-7 with 2.7L V6
1999-2008 Grand Vitara with 2.5L or 2.7L V6
As a result, these gaskets work on the above models.
EGR Valve Gasket (1 required) Fel-Pro part # 71218
More Information for FEL-PRO 71218
EGR Pipe Gasket (2 required) Fel-Pro part # 71026
Oh!
I see manifold gaskets listed, but can't confirm as correct without a diagram. I can look them up on Tuesday at work if no one else chimes in.
Save
I need the 2 for the intake on each end.
There is a bit of mis-information about this. Everyone calls this an "Air Intake" however the Suzuki repair manual refers to this as the "Intake Collector"
By doing research on the "collector gasket" i came across 1 place that sold the gaskets by themselves (not in a set) or as a pair (cuz you need 2 obviously lol)
Home Page | O'Reilly Auto Parts
add your zuk and search "Collector Gasket"
I was looking at your O'Rielly parts link. I don't think those are the ones you need, as they are exhaust collector gaskets. Not that they won't fit / work mind you.
Normally I can get this on-line site to display diagrams and then ID parts, but not today. :huh:
https://partsouq.com/en/catalog/suzuki/part?catalog=US&model_code=JB627W33&group=9
My hardback parts manual is at work, so tomorrow for sure with an OE part number.
You could also pound out some of your own gaskets from generic sheet stock. There are no significant heat or pressure considerations at that joint. Gasket paper and a skim coat of RTV sealant? ;)
Save
yeah i think your right Max, i was going based off the shape of joints.
After looking at this video (although this is a Grand Vitara) the engine looks very similar to the one in the XL7. you can kind of catch a glimpse of the gasket as they pull the intake manifold off:
https://www.youtube.com/watch?v=Nr1bfmHHxbc
it looks more like these:
and just for reference anyone needing an exploded diagram of the intake system see this diagram:
Thanks Max.
I assume it's the same Part # for every year? ( i have a 2006)
i didnt see it on suzukiparts.com after i verified my year. found it on partsgeek, but they only have 1 in stock
parts geek separates the Front from the Rear plenum gaskets.
anyway to tell if the part # is for the front or rear max? (for this thread's purpose)
"Genuine" seems to be the only brand that makes the rear intake plenum gasket, I've googled their part number and found it on another site so i can order 2.
The three bolt holers are rear. The front are two holers, no? :huh:
If you need both ends...get the whole kit mentioned earlier!
Save
Save
I attempted this job this weekend. Started Sunday afternoon and now it's Monday night and and I'm about 40% putting it back together.
Word of advice to anyone attempting this, be patient and don't plan anything besides working on your car.
I ended up having to remove the throttle body first before the intake collector in order to do that I had to also remove the fuel rail. But once all that was out of the way it pretty much was a breeze.
41 - 60 of 73 Posts
Status
