The fun that never ended....
Continuation from here and here.
To date:
-Computer was replaced (with one from the automatic model, in February 2012)
-Timing belt was changed (february 2012)
-Valves were adjusted (2012)
-Head gasket was replaced and head resurfaced (2012)
-O2 sensor was replaced (Summer 2012)
-Oil was changed (last month)
-Coolant was changed (2012)
-PQ valve was replaced (2012)
-EGR was removed and cleaned (April 2013)
-Air filter was replaced (March 2013)
-Timing was set (2012 and again today)
-Distributor and rotor were replaced (summer 2012)
-All vacuum lines and camps were replaced (April 2013)
-Plugs regapped (April 2013)
The injector has been given one bottle of STP injector cleaner.
In cold environments the engine still bogs when cold, when hot the engine knocks when under heavy load and at all times the exhaust has excess moisture and soot which indicate a slightly rich mixture. Oil and coolant levels remain stable. The water temp never goes past half however even though the thermostat is not stuck the car takes forever to warm up when it's cold outside.
To date:
