Does anyone have more detailed tips or tricks for separation of the #1 O2 sensor connectors on the 1999 GV 2.5L V6? I have spent hours trying to disconnect them but there is no room to reach in, press the release tab, and pull the connector down. I read Max's other discussions about how a small screwdriver was used to press the tabs but I can't seem to find the right position from above or under the car to get enough grip on either connector, or even reach the release tab with a tool while I'm shoulders deep in there.
The reason I'm in this mess is because of a CEL that appeared about two months ago with P0154 "O2 sensor circuit no activity, Bank 2 Sensor 1". I followed the diag procedure in the fsm but it led me to "intermittent fault, substitute a known good ECM and retest." Without having reset the CEL or doing anything else, the light cleared the next time the car was started but came back on yesterday while driving, returning the same P0154 code after about 2,000 miles. I bought brand new NTK's to replace both #1 sensors. '99 GV JLX+ 4WD H25A, just turned 100,000 miles.
