Positive feed ?
311 views 5 replies 2 participants last post by  fordem
Hi I have a 2020 1.4 sz5 s cross allgrip can anybody suggest where I can find a permanent positive feed and how to remove the front speaker cover ? Thanks in advance.
#2 ·
A permanent positive feed would be the battery positive terminal (please use a fuse close to the battery terminal - and disconnect the battery negative before doing any work), or, any fuse coming off of the bus in the main fuse box.
Where you connect depends on what you're connecting and you haven't told us that.
#5 ·
Thanks again will meter it out just thought if anybody could point out a obvious one it is always better than lying on the floor trying especially in these temps it is one degree here and trying to snow.
