Hi all, greetings from Sweden. My father in law's precious Ignis MY 2004 with the 1.5 litre M15A 4-cylinder engine had started to judder earlier today while driving, and threw a engine light on the dash. When I connected the ELM327 OBD reader and Torque app, it said: P0303 Cylinder 3 misfire detected.
As I understand the firing order 1-3-4-2 would mean that the fault code "cylinder 3" in this case is the third in the firing order, in essence cylinder number 4, on the other side of the belts and pulleys.
Here's what I've done so far:
Checked all 4 spark plugs. They are NGK IFR6J11 Iridium which I've put in new only 17.000 km ago. Checked gap, and switched the plug from cyl 4 to cyl 1.
Ran engine again, same judder in idle, same fault code.
Switched the coil packs, so the one that used to sit on plug in cyl nr 4 now would sit on plug in cyl nr 2. Switched the other two wires to match the coil packs again and re-ran engine.
Same judder still, same fault code.
So now that cylinder 4 has ran with both a different plug and a different coil pack, it still seems to cause this judder and fault.
What would you suggest is the next step, would that be fuel injector?
I've never had a fuel injector out before, is that easy to test and remove?
Other suggestions?
Many thanks!
Other suggestions?
Many thanks!
