Oxygen sensor wiring diagram.
158 views 10 replies 4 participants last post by  Adele
Hi
The electrical wire pins have pulled out of the plug in the downstream oxygen sensor (has 2 this one is the one away from the engine). It has 4 wires and I don't know which wire connects to which.
Is a suzuki SX4 2009 hatchback.
Wire colours are blue, white, 2xblack. Other side is yellow, blue, red, black/red.
Any help would be greatly appreciated
#4 ·
well...2009 and J20B is an uncommon combination. Though different markets can have different options. The J20B arrived in North America only in 2010....and I just have diagrams for the J20A
which seems similat to the former one that was for the M16 and probably the same (for O2 sensors) if J20B
#6 ·
Regardless of colour combos, the 2 common colours are always the heater (no polarity).
Of the others, One is a ground (Ohm it) the remaining will be the signal return to the ECU
#8 ·
The heater circuit is power and ground, with a filament in the sensor to bring it to temp, that is why it does not matter the polarity on the common colour wires.
