OBDII error code P1351 on Suzuki SX4 1,6 DDIS 2007
7.8K views 3 replies 3 participants last post by  2013GV
Hello guys, has anyone maybe experienced with OBDII error code P1351 on Suzuki SX4 1,6 DDIS 2007. The check engine lamp turns on while driving the engine goes into safe mode and loses the power. After switching the speed over the gearshift the lamp turns off and the car keeps running till the next light is on again (unpredictable how long it will take to get on again from 1 min till next week drive).Any advise from the same experience is highly appreciated. Many thanks 👍
#2 ·
I'm not sure on the specific SX4 code as it does vary across the models depending on engine and market it was manufactured for, but Suzuki usually define the P1351 to the throttle position sensor. I would suggest you need to diagnose the TPS circuit and sensor for flat spots, drop outs and bad connections for a start.
Reactions: LMP and drstevan75
#4 ·
Which speed sensor, theres 5. One on each wheel and one on the transmission. Depending on how that model is configured it could be using the transmission sensor for reference or summating the 4 wheel speed sensors. You will need to look at the service manual for your particular year and model.
