New owner with a question regarding keyless start fob issue.
7.6K views 15 replies 3 participants last post by  2013GV
Hi all, new member on here.
Just recently bought a 2009 Suzuki Swift. It came with 2 fobs. Both will unlock and lock the car via the remote. One of them detects the fob and I am able to start the car no issue.
The issue Im having is with the other fob. I can't turn the ignition to start it and comes up with the red key. Obviously I can start it by manually inserting the key in but this fob seems to have an issue.
Is the fob repairable or will I need to buy a new coded one?
Just for info I have already changed the battery over to rule out a duff battery and checked the rubber buttons are aligned properly in the fob when snapping it closed.
Thanks.
#5 ·
He says he can start the car with the key, which suggests the issue is with the fob, the fob locks & unlocks the car, which suggests the issue is the fob/key pairing, and that is dealt with by using that key when programming the fob to the car, the procedure for which, as far as I know, will be found in the owner's manual.
#6 ·
Its not in the manual for my swift, its a scan tool job on the 2006 up to 2010 models in this part of the world. Hopefully his is different and allows it, but i suspect not.
I suspect he has the integrated button and key type, which is not user programmable
#11 ·
When I hear integrated button & key type this comes to mind...
This is keyless entry, not keyless start - you can unlock the car without inserting the key, but you MUST use the key to start the car.
He says he has a knob style keyless start
It's not the push button. It's a fob and use knob to start car.
The fob image I posted earlier is a knob style keyless start - you push a button on the door to unlock the car, get in, turn the knob on the ignition switch and the car starts, the key stays in your pocket - if the fob battery dies you use the key to unlock the door, insert the key through the knob into the ignition switch and use it to start the car.
As I understand it, the problem he is describing is that he can lock & unlock the car with the fob but has to use the key to start the car - the BCM recognizes the fob and unlocks the car, the immobilizer recognizes the key and allows the car to start, but the immobilizer does not recognize the fob so the key MUST be used to start the car. One key/fob pair works, suggesting the vehicle side of things is functional, the second key/fob pair does not, and that suggests a mismatch between the two.
The knob style keyless start fob I posted earlier IS user programmable (at least on the vehicles I have seen it used with)
#13 ·
I would go ahead & try it - please note - you need to program or re-program all the fobs at the same time.
Best case scenario is both keys work when you're done, worst case scenario the programming method doesn't work for your car, and you end up exactly where you are - the median is the programming method works, one fob is defective and does not program, the other fob (the working one) should re-program.
I'm curious - your owner's manual should document, at least how the fobs function, even if they don't have programming details - does your manual show that style fob?
#14 ·
swifts use a different security module and i think you will find its going to need a pretty good scan tool to do it.
