Message "Service ESP System"
40K views 4 replies 5 participants last post by  MrGMcD
Suzuki Grand Vitara 2009 five speed manual with transfer switch.
The above message will not go away permanently. Helensvale Qld Suzuki agents charged me $90 and told me they could not fix the problem except by the purchase of a new computer circa $2500.
Message has gone away but returns next time engin is started.
All system appear to work correctly.
Any assistance appreciated
Indicates battery voltage drops a bit low while cranking. Check or replace the battery. Qld Suzuki dealers are, as a rule, useless.
#4 ·
Have you disconnected the battery for a short term to reset the Electronics?.
Try it before you buy a new battery.
#5 ·
I had this problem not long ago.
If its still not fixed, go to nearest supercheap. Get them to do an OBD2 scan. $14, if you don't trust the dealer. Read the error code. Find the real problem.
Mine ended up being a worn/ faulty wire between the rear right wheel speed sensor and inside of panel.
