Lights Is This Normal
1.5K views 0 replies 1 participant last post by  Motorhead
The lights on my sisters Swift have stopped working
Sidelights work as does the "flash" main beam..
But dipped and main beam in normal mode won't work...
Testing the wiring I found that the lights seem to have a permenant positive feed going to what I would normal believe to be the negative terminal on the bulb...
If I supply a negative feed direct to the other two terminals in turn, I do in fact get dipped and main beam ??
Is this right or does it suggest a massive wiring fault ??
