harmonic balancer removal 1998 tracker 16v
11K views 6 replies 5 participants last post by  Jimijon
Attempting to pull harmonic balancer bolt holes on balancer do not line up with puller? I am using Y shaped puller, or is there a specific tool?
X2. They're either 8mm hex head or metric socket head bolts. I've seen them both ways.
#4 ·
If you must remove this, do not forget to torque the center bolt properly when you are replacing it. Torque is 94 ft/lbs. By the way, no need to remove the center bolt on the pulley if you are doing the timing belt....???
#6 ·
yes, a couple taps with a hammer and it fell on the floor. I assumed I needed a puller. The elastomer was so bad in the harmonic balancer that the pulley walked towards the rear of the engine destroying the timing cover and wearing a quarter inch off the width of the timing belt. what we thought were squealing belts was actually the harmonic balancer elastomer squealing.
