I have a suzuki multicab with F5A engine. It always ran well until last week. I'm driving from work when it started to sound and behave like the engine is not getting enough fuel. Rather than accelerate when you press the gas pedal, the engine sound will go down, choke then die
. After a while, it starts again but will only run a few meters and will stop again the same way before. The same pattern went until the engine would only start but not anymore able to move the vehicle as it dies when you try to.
The mechanic have already checked the gas line, replaced fuel filter and fuel pump, clean the gas tank and carburetor. Upon replacement of fuel pump, it ran smoothly for about 20 kilometers and the same problem came back again
Is there anyone who knows or have idea on the most possible cause, and solution to this problem? Please help me
. Thanks.
