So i had to replace an engine block on a 2008 Grand Vitara last week due to a lower end rod knock , the normal Suzuki guy is quitting and management didn't want him to deal with such a large project, so i say " ok i'll give it a shot ". I work as a Chrysler tech btw.
Prolly one of the worst decisions i could have made.
check the carnage in the pics....
Engine has to come out of the bottom, with trans., cradle, mounts, driveshaft, front diff...
engine/trans/diff/cradle/mounts/ taken out
New engine block, heads, cams already installed. I turned the crank over a few times with a wrench/by hand and timing marks still lined up after several crank turns, no binding, and i hear the hiss of the vacuum as the pistons go up and down, also shined a light into the intake and i see the valves open when the piston goes down and close when the piston comes up. Neway.
So Suzuki has no long block available, had to swap, upper & lower oil pans, all 4 chains, oil pump, oil pickup, both heads, 4 cams, sprockets, front cover, this is all that was left of the old engine. This would be an impossible feat in your driveway so please do not attempt.
So the supposedly 20 year Suzuki tech-just-turned-asst.-service-manager wanted to be involved since this was my 1st Suzuki engine ( have done Chrysler engines so far ) so i had to learn timing, specs etc.
so i hook everything up after about 1.5 weeks of waiting on parts, swapping sh!t over etc. I put the engine back in the way it came out, hooked up all the wiring harness/sensors, connect the battery, Now the engine doesn't start.
I have 150 psi across all cylinders, have fuel & spark , ( checked with NOID & w/ spark checker ) have code p0341 cam position performance.
Is it possible the cam pos. sensor got fawked up? I DID bang around the front cover with the sensor still installed. Or possibly even the chains off a tooth/teeth?
I turn to the Suzuki experts, could the cam sensor be bad/damaged or could the timing be off? I called the Suzuki techline to see if there was any more info they could give me, but they just told me to swap a known good cam sensor & go from there, they also told me that P0341 would cause a no start.
The vehicle doesn't start, just cranks, i smell crazy fuel & the exhaust blows black smoke, before putting it all together ( just so i would only have to do it ONCE ), i had the Suzuki tech-turned-manager verify my timing marks on the 4 chains, he said it was ok.
So i'm pulling my hair out trying to figure this out, it's acting as though it's getting unmetered air past the MAF sensor , like almost a vacuum leak, running pig rich, blowing black smoke, but it doesn't run.
I figured this would be the best site to consult with since many of the people on this forum are prolly life long Suzuki owners.
TIA
Agreed, nightmare?
TIA
Agreed, nightmare?
