is it not:
HO2S Heater Circuit Malfunction Bank 1 Sensor 1 ?
this says , the heater is open
or
it is too slow to heat O2 sensor to the proper temperature quick enough. [ OBD MONITOR software test]
Seafoam is great for fouling O2 sensors, never use it. " see smoke , then you are killing your very expensive sensors."
if you must throw something IN THERE , Techron FI cleaner is safe ( mostly benzine and xylene ,costs more and is safe. )
Using after market O2 sensors is ok if: (assuming bare lead variety)
1- correct part number
2- you solder the connections using special flux (ask me) ( butt splices are NO GOOD , unless you have the fancy water proof kind, I dought you do)
wire nuts , NO. twisted with electricians tape, NO., now you see why most people cant get it correct.
3- you connect it with the correct color code , cross over rules.
if the above is done, then I guarantee the Bosch will work. ( the prewireds are up to $100 more expensive but are PLUG and PLAY)
if you desire to save money , you are obliged to do it correctly. ( or will be doing it again soon)
BUT...
FORGET ALL THAT.
I suspect your car is busted, it is running badly.
explain that first.
DeAccel DIE ? define Rough Idle?
I think you have an air leak , sounds like your ISC,IAC is leaking air and is all clogged up with PCV vapor contaminations (common).
Your engine can not control its idle curcuit. Is my GUESS.
other commons:
EGR stuck open. ?
ISC,IAC stucking,
MAF is dirty. special cleaner needed.
Factoid:
The OXY sensors have special SST wire the are hard to solder. But there is a cheap flux that solves that riddle.
tells us more.
