Is there a way to dissable the start/stop permanently? I have no doubt that the start/stop system is friendly for the environment. But I doubt that it's friendly for the engine and for the battery.
I attached ONE magnet a little smaller than that one in the picture in the same place, in my Celerio, and it made zero difference. The damn stop start still worksI personally tried to attach a neodymium magnet to the sensor at the minus pole of the battery.
The sensor evaluates this as a low battery and disables Stop/Start.
But be careful - the battery is permanently charged with a voltage of 14.4 V and does not work with the help of a hybrid drive.
That's interesting - you have a car with auto start/stop that doesn't have keyless start?Key in, clutch down, turn key, hit start/stop-off, engage first gear, handbrake off, clutch up, pedal to the metal.
If we consider Suzuki's approach to disabling auto stop/start as "temporary", from the point of view that it defaults to on every time the car is started so that the driver has to disable it on every start, could disabling it from a menu item so that it defaults to off, and remains disabled on every start be considered "permanent"?The reason why manufacturers don't fit a permanent override facility is because of the WLTP largely theoretical measurement of official fuel consumption. The test would be done using stop / start if fitted and giving the facility to permanently override may well result in accusations that the official test results were skewed.
You're in the UK, so it's not likely you would have come across this one - a GMC Acadia, and not all of them have it.Of all the different cars I drive I’ve never come across one where the stop + start can just be switched off permanently. Which are the cars you talk about that have this?
...maybe I'm wrong ...because I'm not sure if it is the best for the battery when the loading-regulation is deactivated............Nothing could be simpler (and easier to reverse) on the Ignis than the magnet trick - why would you want to do anything else?....
It is, and has been for several years - so called "smart alternators" reduce the alternator output to reduce the mechanical load on the engine under specific conditions and when the alternator output is reduced the system voltage drops and the "excess output" which is what would be charging the battery goes away. This however is unrelated to the battery state of charge sensing and is done with a current sense element in the main fuse panel.I thought the charging power will be also controlled by a control unit in modern cars .....
With this hack, you should be able to buy a much cheaper not stop/start spec replacement battery if ever needed.Start-Stop is gone!
eBaycould you please put a link where to buy those neodymium magnets online
I have read the functions of engine starting and electrical generation have been combined to be done by the one unit which saves space and weight.it uses a different starter motor. Why is that?
