Check engine light wont go out on 1998 Vitara
1 reading
35K views 51 replies 5 participants last post by  autotune
Hi there, I'm new to this but I'm having problems with my 1998 Suzuki Vitara 16v. About a month ago my check engine light came on and it was starting to stall at junctions and traffic lights. I have changed to distributor cap and the Lambda sensor and the spark plugs and this seems to have sorted out the stalling, however, when I disconnect the negative to the battery, the light seems to reset but as soon as I start my engine, 30 seconds later it comes back on again. :confused:Any one any ideas what it could be. I've had the manual out and it seems to say locate wires under the steering wheel and switch the switch to the opposite side but I've had half the car apart and can't find any switch!!!!! Can anyone please help me????Thankyou. :)
#32 ·
#33 ·
ah finally a vin, your car was made in Spain, a santana. VSEET
congrats on album, like the first ever here. your MAF (air meter ) is the world
wide ubiquitous 58B00 MAF.
nice not guessing for all..
so do a ww search on that P/N .
at $900 uSD a pop , id bet tax is the least of worry, no?
actual correct page for your car.
#37 ·
see that PN.
that is your pn
if seller is not fibbing on that
or not fibbing on photo
its the correct sensor.
we know your correct pn,
we looked it up
and hopefully you looked on the side of yours and read it. did you?
they all have a sticker with the pn right in plain view.
some get old and fade out.
but not looking , asks for trouble. no?
#38 ·
fixing cars is easy
finding cheap $900 sensors, not.
and as time passes less and less good used MAF, no?
ropes:
Fleabay or Fleabaystores.
send email to seller.
hello sir
is this photo the actual sensor.? (i bet not)
and
is the sensor marked as stated, 58B00?
and last
do you guaranty NO DOA?
do you guaranty 58B00 part.
i dont care what he did, what i care is , is it guaranteed. IMHO.
#47 ·
im sorry yes it is. (i guess you never saw one in UK ?, they are all over EU) the page clearly says AIR FLOW METER !
do you need a photo of the EPC page. ? see attach.
she even showed a car with it installed! see all posts.
here is my MAF page.
---------------------------data from my hard to find parts page----------------------\\.6L 92-98. Type 3 MAF's
The MAF prefix is always 13800- all Sidekicks and Vitara's
Also, there is a type 2 MAF for EU /Australia Vitara 13800-57B00 1.6L 16v MPI
Looks like toilet plunger MAF, fits ECU 57Bxx , I have no alt. sources.
type 2 motor has ISC located in Throttle body and not on intake manifold.
58B00:
Which MAF's fit my car , is answered below.
#1 Source: (Suzuki is over $800 new)
#2 Source: ROCKAUTO.COM (A-1 Cardone is ok) see emmission section not Air/fuel, oddly
Last change:
ALL-IGNITION.com for 1.6L MAF : 1.6L MAF cheap but rebuilt it says AND OUT OF STOCK MOST DAYS
Sadly, (All-igniton said their "supplier recalled the 1.6L rebuilt MAF's April 2010")
Suzuki PN for this part is: 13800-58B00 Type3 fits all USA 92-98 1.6L My list of Suzuki cars, that use this part number.
Other Suzuki's any Displacement using type 3 MAF 58B00:
99-03 SQ416 same prefix , 65D00 MAF. Vitara, all below.
99-03 SQ420 same prefix , 65D00 MAF, 400 more CC and same MAF !
99-05 SQ625 , Suzuki moved MAF to TB and dont sell MAF by its self. see below for solution.
01-03 JA627 , Suzuk moved MAF to Air cleaner again. same prefix , 52D00
04-05 JA627 , 52d10 Suffix.
Suzuki MAF's are for sure hard to find.
This dont exist, ok, sure. EPC data
#48 · (Edited)
I guess you've never seen one? they're all over the UK. If you look at your photo it clearly says Air Flow Meter not Mass Airflow Meter. Its not a MAF its a Volume Air Flow Meter (VAF) and is not compatible with a 1998 UK spec Vitara.
#49 · (Edited)
ok i get it , a word argument.
OK
you win
so what's the fracking point? i helped her find the correct part
why argue , name conventions.
the part number was stated correctly.
http://papers.sae.org/890301
id not expect any UK guy to give a hoot for SAE.org but they to , call it other things.
"A Hot Wire Air Flow Meter for Intake Air Flow Measurement"
i'll be danged. the name game. wow.
#51 ·
I think you're confused, I stated that the 57B00 isn't a MAF. It isn't a hot wire sensor as you have already stated and its output is proportional to the volume of air flowed and not the mass of air.
#50 · (Edited)
My point was that she needs to ensure that she gets a MAF (hot-wire type)and not a VAF (mechanical type), its not a word argument they are different parts. I was reiterating your point by stating that the 57B00 won't work and why it won't work.
UK breakers rarely sell by part number but by make, model, year(s) and part description which can make sourcing parts more difficult.
