Hi
I have an issue with the central locking on my 2016 Vitara.
Key fob worked without issue then gradually went to intermittently working to a point where it's now no longer working.
Obviously tried replacing the key fob battery which I've done without success.
As well as this, the fade light doesn't work although I can manually click it on so the bulb is working.
From my understanding it could be down to the BCM or Dome fuse, which I've checked and appear OK (not blown). Ive also replaced these using the spares Suzuki give you under the bonnet.
Are there any other fuses I am missing or another issue it could be apart from replacing the BCM itself?
Thanks for reading.
Thanks for reading.
