Buying second hand Suzuki Grand vitara - early warning signs
1 reading
14K views 36 replies 10 participants last post by  Cherod
I am new to Suzuki Grand Vitara's and know virtually nothing about cars ( apart from how to drive them).
I have been navigating may way through Which car review reliability ratings and it seems that Suzuki are rating high for reliability. As a result I took a leap and decided to buy a second hand Vitara 2007 model. I've now had this car for a week.
I was very happy with my purchase at first apart from a very early warning sign, when I was driving it back from the dealer:
There was a strange loud whining noise (almost sounding like a high pressure build from somewhere) and the car shut shown, there was a slight burning smell. However, at the same time I had also stalled the clutch. So I attributed this issue to my own error.
I also noticed the engine light had come on. I contacted the dealer who said that it could have appeared because of repeatedly stalling the clutch ( because Im new to driving this type of car) and that it had registered as an error on the engine onboard computer (?).
I also checked on the Suzuki website and one of the reasons for an engine light to appear on the dashboard is due to the engine inlet not being fastened securely. I then fastened the cap and the engine light disappeared.
From this point I thought there would be no further issues.
I test drove my new (second hand) Suzuki on the motorway , within 10 mins the strange screeching sound happened smoke came out of the exhaust and from under the bonnet, (there was a huge amount of smoke leaving the bonnet to the extent that i thought it would catch fire!). Luckily I managed to steer onto the hard shoulder. further investigations following recovery from the motorway included :The engine coolant had oil in it, the central heating didn’t work.
I have several theories about what could be wrong with the vehicle, top of the list is head gasket.
My question is, having only just purchased the car, is it worth getting it repaired? Surely any number of things could happen even if its repaired?
I have explored the forum and another person replaced the gasket on his Vitara but the car broke down a year later due to a split in a valve somewhere!
Any thoughts comments greatly appreciated (especially from someone that specialises in Suzuki engines)!
First - the dealer is already BS'ing you - you're never going to get a check engine light because you have repeatedly stalled the engine due to any sort of unfamiliarity with the clutch.
Moving on, any time you get a check engine light, the EXACT cause of the light can be determined be reading the accompanying code, leaving the fuel tank cap off can cause the light to come on, the code there won't say the cap is loose, it'll say something along the lines of a large leak in the EVAP or fume recovery system.
Cross contamination between the lubrication & cooling systems is bad, VERY BAD, it can be a simple issue, such as a leaking head gasket, it can be a warped head, which, depending on how badly warped it is, might be fixable, or it might need a replacement head, or it can be a major issue, such as a cracked head or block, at which point you're looking for a replacement engine.
Since these problems have shown up immediately after purchase, and as early as the drive home from the dealer, make it their problem - I wouldn't want to see that car again.
#6 ·
Thanks everyone for your replies on this, it's quite daunting trying to negotiate with 2nd hand car dealers, So far Ive not had a response on what's wrong with the car and I also haven't had a refund. So no car AND no refund. I was hoping that it would be something simple like a coolant leak but after reading your comments I may have to go with the logical answer ... I will let you know what happened soon...
#8 ·
Hi ,
According to the CR Act I do have the right to return the vehicle however, I am now being told that culpability is still being considered, in relation to the fault. In other words the damage is probably extensive and giving me a refund and paying for the repairs will lead to a significant loss. The only information I have been given is that a pipe has split leading to a loss of coolant and an overheated engine. When I ask about the extent of the damage to the vehicle, I am told that they wont know that until they try to fit the new pipe that has been ordered from Suzuki and if the water circulates and the engine starts, the engines ok.
Wouldnt the mechanic usually dismantle the engine to check for damage? Are you able to check the head gasket and valves without this mysterious pipe that has split (that only Suzuki provide) ?
There is definitely a push for me to keep the car , worst case scenario: what would happen if I take the car back? Is there a way to guarantee that it wont break down again? Unfortunately I don't have a scary uncle that can talk sense to this guy and whenever I say the word refund I am presented with an argument about "liability." Because I may some how be at fault for the extent of the damage to the engine for not noticing that it had overheated.
#9 ·
Hi ,
You're being BSed.
First - assuming this is a gasoline (or petrol) engine, no coolant hose or pipe will allow the intermingling of oil & coolant. As I said earlier, at the very least there is a failed head gasket.
Second - a compression test can be done with no coolant in the engine, compression tests are done to determine the "general condition" of an engine, low numbers across all cylinders suggests a worn motor (or incorrect valve timing), significant variations between cylinders, point to a compression leak somewhere, possibly through a defective head gasket, the compression test can be followed by a leak down test, which may or may not provide conclusive data on the location of the compression leak.
The tests mentioned to this point can be done WITHOUT DISASSEMBLY of the engine - if the compression tests show evidence of a compression leak which cannot be pinpointed by a leak down test, the next step is disassembly and a visual examination.
The fact that you have mentioned oil in the coolant is as I said before, a VERY BAD SIGN, and on that basis ALONE, I would not want that vehicle - from what you are telling us, they already know "the damage is probably extensive", replacing the pipe/hose refilling it with coolant, starting it and handing it back to you is probably their intent, and then you're saddled with the problems after that.
There is no way to guarantee it won't fail again, and whilst this is just my opinion, I'm inclined to say it's guaranteed to fail again and very soon - failing a refund, which is my first option, I would want some sort of extended warranty covering the entire powertrain, and that would have to be in writing.
I think it's time to get legal advice, maybe talk to the folks that bvs has suggested.
It is irrelevant what is wrong with the vehicle Ray - I would just firmly ask for full refund and as Fordem suggests above take legal advice if required - I personally would not want to keep any vehicle with a major defect.
Once you accept the vehicle back it may muddy the waters a bit - if you are entitled to a full refund just take it as quickly as possible.
#12 ·
Appreciate the advice so far.
I have just been advised by the car dealer that the Head Gasket has gone, he claims that upon further investigation ( by a Suzuki garage), it appears that a stone from the road caused a crack in the raidiator leading to the engine to overheat. As a result of my continuing to drive the vehicle and not notice the engine was over heating the head gasket broke ( something along these lines). It has taken 10 days to come up with this story which he now claims can be verified by a Suzuki garage. I am therefore being held responsible for the fault. The frustrating thig abou this cowboy is that he had used this line of argument from the very beginning suggesting that he just needed more time to try and come up with a story that would be plausible but difficult to prove.
Any ideas on this? Surely a Suzuki Vitara 4 wheel drive is designed to deal with stones flicking up off the road?!
#14 ·
Temperature gauges don't tell you when the engine is overheating, they tell you the temperature of the coolant, if there is no coolant, then they don't work, there HAS to be coolant surrounding the gauge sender/sensor for it to be able to measure the temperature, so it's not only possible to loose the coolant and have the engine overheat without the gauge showing it, it's actually quite common.
Go stick your head under the nose of the car and see when the radiator is located and what's underneath, chances of a stone striking the radiator, whilst not impossible, are in my opinion extremely low, the radiator is actually quite well protected, take a look yourself, and having done that, ask the car dealer, where the crack was, so you can see where the stone would have had to pass through.
You can also use feraltek's question against the dealer, ask them how were you supposed to notice the engine overheating, it never showed on the gauge.
#17 ·
Generally speaking no, none of the vehicles I've owned over the years (five decades give or take) have had a way to indicate the coolant level is low (and that, by the way, includes a third gen GV) - I do remember, driving down the street going to a service call (back then I did tech support for the travel industry) and noticing the temperature gauge was higher than normal, I was about a block away from my next stop, so I continued and checked under the hood on arrival, there was a pinhole in the top radiator hose, and the system was loosing pressure rather than coolant.
I called my wife who was at home having lunch and asked her to bring the required hose, yes, I had a new one on the shelf, I replaced the hose, refilled the coolant and went on my merry way - I did purchase & replace all the remaining coolant hoses on the vehicle (a Suzuki Swift), shortly after that.
It was not just a coincidence that I had the required hose on the shelf, I had noticed the top hose was getting soft and knew it wasn't far away from a failure, I could have replaced it before it failed, pre-empting the failure, and were I doing more than "running around the city" I would have.
Routine preventative maintenance is important, if you need a reliable vehicle, you have to stay on top of the maintenance, you don't wait for a part to fail before replacing it, a quick "visual scan" once a week, can save a lot of grief, inconvenience & expense - I do my a lot of my own maintenance on my daily driver, but my daughters' vehicles go to a trusted independent mechanic, if he finds something that needs immediate attention, I'll get a phone call, if not, when I pick it up, I get a list of things that need to be addressed - you're going to need brake pads for the next service, or the control arm bushes are going, I get the parts and put them aside for the next service.
This approach doesn't really work when you've just acquired a used car, unless you take the used car and have your mechanic give it a once over.
#16 ·
You say you've only had the car for a week. In this time have you been on any roads covered in loose rocks where the radiator could have been damaged? If not, then the damage occured before you bought the car and would have overheated then, probably damaging the engine. In which case the dealer sold you a car that already, or was about to, suffer the consequences of previous negligence and is therefore fully liable to cover repair costs. By the way I just had a look through the grill of my GV and cannot see how a rock could have damaged the radiator without first punching a hole in the a/c condenser in front of the radiator. Also it seems almost impossible that a rock could bounce up from underneath. Most likely the Suzuki people pressure-tested the cooling system and detected a leak from the radiator and someone just guessed a rock must have hit it without thinking it through.
#18 ·
Here's a guy (or gal) that's on the ball - the bumper almost literally wraps around underneath the radiator, and the a/c condenser is front of it - the exact reason I said the chances of stone damage were extremely low.
#23 ·
A mechanic advised me that this would be the only possible way that a fault could occur accidentally as a result of driving it over such a short period of time (he's not connected to the dealer). Its reassuring to know that you live on a farm and the car may be exposed to rocks rather than small pieces of gravel and you've never had a problem!
#24 ·
So the bare bones of the issue is that I'm still no closer to getting a refund and I still dont know where the vehicle is. And even worse still... the explanation given is actually not based on a mechanical inspection from either of the garages ( as they have told me that they havent had time to look at the car yet)! According to quotes Ive had so far a professional engineers report ( to determine the cause of the fault) will cost hundreds of pounds. It seems like I may have to cooperate with the dealer to a certain extent just to know where my car is and have a change of getting my money refunded but in doing so the problem becomes worse. Its like having your arm twisted behind your back! As Fordem said in the very beginning he's blatantly b'ssing me ( and i dont think he means blessing me).
#25 ·
Have you looked online for customer reviews of this dealer? Often this will give an idea ot the dealer's reputation and what recourse others have used to get some satisfaction. There was one Suzuki dealer in Queensland Australia who had dozens of really bad (one star) reviews but he also had a couple of hundred brief 5 star reviews with nothing much in between which was odd as no other dealer seemed to have more than 50 reviews in total. Not very difficult to guess which reviews were genuine.
#35 ·
Good point - Thanks to everyone that has posted on this topic, your posts have been very enlightening ! I almost definately have gone with a repair had I not have posted here first.
Back to aquanaut20's point - What are the top 10 things I need to look out for when buying a second hand Suzuki Grand Vitara - on this occassion I went through every detail on my checklist and couldnt have anticipated that a blown head gasket would happen within a week.
What should I look out for in the future and should I avoid models over a certain age?
