Bex,
thank you for your thoughts about my challenge. I am a newbie in all what comes to Swift. My sister's car...
Anyhow, it's just odd that there is clearly that sensor in the failed gearbox very near the differential (well, based on photos, this is what I think). But, that sensor isn't visible in the official diagrams on the gearbox brought up by the VIN of this car - like in the diagrams you've referred to in your post (and as in the ones in my post).
Could this sensor somehow be illustrated somewhere else in the drawings - where ? If it is odometer or speedometer, should I search among the electronics diagrams ? What do you think ?
Also, there is another thread that indicates a similar component/design btw. two other variants for Swift (1.3L) gearboxes ZN0 (with sensor & ring) & ZN3 (without sensor nor ring, just a blanc lid covering the mounting hole - that's the version they got for my sister, instead of variant P34).
See photos:
https://www.suzuki-forums.com/members/bxr_85.263392/
And, to me it looks like the ring the sensor reads would be shown just within the differential sub-assembly, like that part nr 14 in the diagram.
Also, when you search for Suzuki part nr S-26121-62JE1 (part 14 in the part list of the diagram)
RING, EXITER | 14 | 1 | TYPE 1 JSAEZC11S00100152~ JS2ZC11S 65100451~ TYPE 2,3,4 |
you'll find e.g. these two illustrations that really resemble something like what a inductive sensor would need:
When I compare related variant part lists, it looks like some of the differential's parts were slightly different in two of these variants. Like the "27411", that ring and the bearing at the end, perhaps also the end sealing. But, it could well be that if these parts were changed over from failed gearbox to the replacement one, it just might do it.
Unless the left drive shaft were of different diameter than the bearings, of course, then also the bearings would need to be changed over, taken that their outer diameter would fit the cover. Or, something else that are not given proper measures was different...
Uuuhhh... I wish I had that car in my own workshop for actually checking these things out myself, and not like it being in a far-away who-knows-what car "service" shop having already the gearbox removed before actually verifying compatibility, first :-(
All opinions/angles greatly appreciated !
