93 Geo Tracker 2" coil spacers dimensions?
19K views 15 replies 8 participants last post by  nuno_leonor
Hey all, new to the site and new to the tracker world.
I have a buddy that owns a machine shop and hoping to get a 2" lift kit machined up.
From what I understand for the 2" spacers lift kit I'll need 4 coil spacers, 2 strut spacers, 1 rear diff spacer. I was wondering if anyone has the dimensions for these parts or if anyone could point me in the direction of getting them.
Or any info on something I'm forgetting maybe..
Any help is greatly appreciated.
Thanks,
Connor
#2 ·
hi brad j here my 92 sidekick 4dr runs good after getting my rebuilt coumputer reapaired my next project for the spring is a 2" max lift preferable with coils and no spacer to run 235 75 15" tires it is a stock 1992 sidekick 4dr 4x4 1.6 16v are the any coil combantions i could hunt down at the auto wreckers i can search out longer shocks and do some fabing of small parts at work i will need caster bolts and an alingment i would like to stay with the stock alumuin wheels they look good i don't want to go up goat trails (thats why i sold my samurai) is there a benifit to getting ford 0 offset wheels ? thanks brad j
#4 ·
Thanks for the welcome and the info Bex!
I've searched the forum a bit but didn't find what I was looking for.
I have no problem spending the money and buying a kit, I'd probably go with SR Customs. I just think it'd be cool to have my own machined up.
I'd be willing to pay someone for the dimensions and info even!
#7 · (Edited)
No longer looking for coil spacer dimensions. Now interested in finding out the inner and outter diameters of the coil springs. As in what size tube fits directly down the center of a coil spring. Anybody have any coils laying around they're willing to take some measurements of? That'd be great!
I've gone over this thread a few times but keep getting confused after each time I read his measurements..
http://www.suzuki-forums.com/suzuki...uki-sidekick-escudo-vitara-geo-tracker/40805-cheap-spacer-lift-easy-if-you.html
Thanks!
#8 ·
I have some rear 2dr springs... I did 4dr spring upgrade gained 1" front and rear.
I will measure my rear 2dr for you with pictures, but the front springs grew legs and disappeared. Not sure the front would be any different in width though. Have you just considered a simple 2+ body lift? Square 2" tubing with holes drilled and longer bolts and some nuts does it. And with 1" in spring it clears 30/31.
#9 ·
Hey Cody, thanks that'd be great. I plan to do a 2" body and 2" suspension, wanting to get the body mounts machined up as well.
I've been working on some 3d designs for the spacers. Going to make some designs for strut spacers and body mounts too. I'll post up the pictures when I get them done.
Thanks again.
Here's the diagrams I've been working on for the spacer kit. These images don't show the measurements and they aren't exact yet. Just a general idea.
On the coil spacers I made a 1" section to go inside the coil, is that too much?
1.5" front spacer
1.5" strut spacer
2" rear spacer
2" mount to go between the rear shock in the frame, rather than using longer shocks
Let me know what ya think!
#13 ·
ConnJohn, I know this post was back in 2012, but for a chance did you finished the dws? and also more important, are you able to share those?
Right now I am at teh same point you were there back in 2012, want to machine my owun lift kit.
Regards
Dmx
Geo Tracker 1993 4x4 manual transmission.
#11 ·
#12 ·
I used the first link you posted as a reference earlier today to start on the body mount design.. Working on figuring out the dimensions on the washers, two bolts, and stud extenders.
I found a bit of info referencing a stock body mount bolt and a lift kit stud extender and came up with the bolt, excluding the head, to be roughly 2 7/8" and the aftermarket extender to be ~ 1 7/16".
The images I already posted before are basically replicas of the second link you posted.
Now I'm going to research around for any basic info/dimensions on the upper control arm bracket and mock up a design for that as well.
#15 ·
He hasn't even logged in since 2013. :(
You could try a PM (start a "Conversation") with him. He may respond if he receives notifications.
