2017 Swift - Inspect Cruise Control System issues
1 reading
26K views 12 replies 10 participants last post by  2013GV
Hi,
Does anyone have any knowledge of sensors/system issues with a 2017 Suzuki Swift?
Warning message coming on which states that I need to inspect the Cruise Control System. Checked the fuses, the radar sensor and the behind front mirror cameras visually but nothing obvious. Cleaned the sensors but message remainand cruise control doesn’t function.
Any experience out there and does this cause any issues with being able to drive the car safely?
thxs
#4 ·
the fact you have a money maker light lit says you have a fault somewhere. get it scanned and report back with the code it gives you.
Reactions: AnteSwift
#9 ·
I'm not certain where you're going with this, the discussion appears to be in the "2004+ Swift" section of the forum, not in the Baleno Section, and I've had a look at the system logs, it does not appear to have been moved since you posted.
That said, users don't always post in the correct section of the forum - if or when the error is noticed by a moderator, he/she can move it, it could go unnoticed for years - why are you making an issue out of it?
#13 ·
Not usually but it will show whether there history occurrences since last code clearance
