I have a 2006 Swift and the Airbag Light is staying on Solid.
When you start the Car the Airbag Light flashes 6 times then goes off and comes on Solid from there.
I have un-clipped and re-clipped the connector's under both Seat's and also at the rear of the Glove Box - then disconnected the Battery for an Hour but no change.
Next I will remove the front Seat's but I need to get a special socket for this as the Bolt's have a Torc head on them - then check for any break's in the cables.
What are these cables connected to on the Seat's and what should I be looking for here?
Also there is a cable going to the Seat Belt receiver on the Drivers Seat - should I open this?
Any suggestion's / help - much appreciated.
