Lost the key and the immobiliser transponder to my Swift. I've got hold of a breaker's ignition assembly and key, and I have a few questions that someone may be able to help with.
1. The attached photo shows (arrowed) a small black plastic thing - is this the immobiliser 'receiver'?
2. If it is, then I need to bypass it. The way to do that might be to connect the two green wires in/out of it, but I'm not at all sure. Can anyone confirm/deny this?
3. If it's not the receiver for the immobiliser, where is it and how do I bypass it?
4. Then there are the two bolts holding the assembly to the steering column. On my breaker replacement, these show evidence of centrepunching, probably to get them to loosen for removal. Is this an OK way to get the old unit off, or is there some easier method?
That's the lot.....thanks in advance....regards Peter
