Good afternoon everyone...this is my 1st post as the new owner of a USA 1995 Sidekick, 1.6L, 16 valve, Automatic W/ Overdrive transmission. My question is that my oil light flickers constantly after the motor has warmed up. I hooked up a manual gauge & the oil pressure at normal operating temp is right in the range where it should be at 4000 rpm(60 psi). However, when I let it drop back to idle it will stay at a constant 20 psi. I have already changed the oil & oil pressure sensor switch & I'm about to install a actual dash mounted oil gauge so I can monitor it while driving. Is this safe to drive at 20 psi idle? The thing runs & sounds like a sewing machine, no knocks, pings or other gremlins. Also, when I install the manual gauge how can I de-activate the idiot light without having to take the dash apart? Any ideas would be greatly appreciated............Thanks!
