What about a wider SUSPENSION conversion?
1.2K views 1 reply 2 participants last post by  Bex
Not just wider tires and rims getting offset and bearing wear issues.
So what about a wider suspension to fit much much wider tires and rims?
Of course you'll also need fender flares.
#2 ·
Is this regarding your 'roll-over' issue? Just for your info, although wider tires may help in dry conditions, they are worse in wet ones, as the weight (imprint) on the tire is dispersed over a larger area (wider tread), which doesn't allow the tire to grip in slippery conditions as well.
