Sidekick/Tracker tailgate handle replacement.
11K views 21 replies 6 participants last post by  we're_using_codenames
Since I bought my Tracker I can`t open my rear door from the outside(when hardtop is on). I`ve read many messages/articles saying that this part is kind of weak on Sidekick/Tracker.. I think it`s more problematic in cold area. I have to fix it as it would be sometimes very useful to be able put stuffs in the back of the Tracker by this door..
I took pictures , I`ll upload them in case it could be useful to someone someday...
I unscrewed the two bolts (from the Inside of the door), that are holding the tailgate handle. there`s a plastic and a metal part. The metal part is rusted and the plastic part is broken, so no wonder why it was impossible to open the door ! I also unscrewed (from Inside) the black plastic cover, on which light plate are attached.
In the workshop manual there`s not a lot of detail about it. there`s a piece of plastic, a part of the handle, that goes trough the metal door(in a hole). But I`m trying to find on which piece it`s attached(Inside the door). I might have a part missing.
I`ve read that some Sidekick owner built their own metal tailgate handle. I`ll probably go to buy a rear door at the scrap yard to be able to fix it. I`ll be able to take measurements of it and I`ll to be able to build one in metal and replace it later....
They said a good door is $50, I don`t need a nice one as long as the handle is working.....
Even if it`s not a big job, I`ll take other pictures of the installation. btw, just can`t wait my dog to get in the Tracker by the rear door instead of make dirty my seats !!! lol
A lot more detail than in my manual. #9 is the broken part. Parts 12,13,14 are those I think might be missing, but I`ll go watch to see if they could be laying somewhere in the door.... As it was attached on the broken platic part from the handle(part #9) it could indeed still be in the door.....
It so cold today, I might be waiting tomorrow to work on it.....
#4 ·
My handle was broken when I got mine. The PO rigged a piece of thin cable, like throttle cable, to the opener-thing and all I had to do was pull the little cable to open the gate. I later got a handle from MDON40's donor truck (thanks again bro) and it was a super simple swap/fix.
#12 ·
When mine broke on me I did the same thing..just a thicker piece of wire coated with plastic ... Still in use. :) I'm a cheap @%@*^%$. :cool:
#5 ·
#6 ·
Thanks guys. However what I want to do is to find a cheap door at the scap yard for a temporary fix. As I dont have the inside door panel it will be a cheap way to get that piece to. Then next spring, when temprature is going to be way warmer I`m going to build a metal handle and a stronger mechanim.
When I`ll get it I`ll post pictures of every pièces so it could help someone in the future(even if it isn`tt a big job!).
Just as an aside, we had a poster some time ago that purposefully removed that tailgate panel, and used that area as storage for fluids, jumper cables, etc. At the time, I thought it was a brilliant idea.....
#9 ·
Not a bad idea to use that space. However as it`s cold here in winter the tailgate panel is useful to keep the inside warm. However a trap(kind of little door) in the pannel could really do the job. Furthermore, in summer when the top is out that area could be useful to hide some useful things(few Tools for exemple).
I`ll take a look at it for sure.
My panel is just made of cardboard....not normally considered a good 'insulating' material :) Unless of course, you have insulated the space in between? PINK insulation?? ;)
While the cardboard may protect a bit from drafts, I'm not sure that it really does more than that - and if you have the convertible (or any rust holes in your floorpan, like I do), heat is being lost from the cab anyway....
#11 ·
"While the cardboard may protect a bit from drafts" that is exactly to protect a coming draft when it`s really cold. it makes the habitacle of the Tracker a little longer to warm up without it. (when it`s between -15C to -30C)
Btw, hard top is not so bad in cold weather. Indeed my passager floor pan was letting some air coming but I added insulation so no air from there....
#13 ·
Hey guys, where do you pull that cable from ?! not by the hole where the handle was ?
#14 ·
Been awhile since I did mine... Take inside panel off and find the mechanism that opens tailgate attach wire and route to outside. If I recall correctly.
#16 ·
Ok I got it for the very temporary fix. When I was opening from the Inside of the truck I had to push up the rear gate latch. but, as it swings up and down, just about two inches on driver side you can pull it down. so it`s where I attached a wire.
I`ll have to wait 2 or 3 weeks before going to buy a used tailgate at the scrap yard so it`s going to be ok until then. When I`ll have that spare door, I`ll cut the Inside to take pictures of the mechanims in action.
It will be way easier to put those 40 lbs wood pellets bags by the tailgate And also to get my two dogs in by this door to.
I might even have time to build my metal tailgate handle by then...
#18 ·
I just used tyraps and it seems to be strong enough. it should be ok for few weeks. thanks for the idea guys.
#19 ·
That may hold for a while. If you come across a brake cable from an old bicycle or something, it will work long-term. The one that was on mine was just that. The guy left a two inch piece of the cable tube on the cable and made a loop on the end. That's the part sticking out on the outside. The plastic/rubber tube piece was left on there so you could pull the cable with your finger(s) and not have the cable cut into you. I believe you can buy that cable by the foot at hardware/home improvement stores. Then use a piece of rubber vac tubing inside the pull loop.
#20 ·
StreetKing, I just wanted a temporary set up as I`ll build a new metal handle tailgate, and the mechanism in which the spring is. It will be a lot more tougher than the set up it had first.
However, as for now, this temporary fix is going to be very useful.
