Sorry, this topic has been here several times, but I dindt find answer to my problem from earlier posts so here we are.
I replaced my clutch cable and new cable seems to be correct part. I have tighten the nut number 19 so that I cant feel anymore freeplay in clutch lever, when I push it with my hand. I would not like to tighten it anymore to avoid clutch wreck. Problem is, now when I press Clutch pedal to the bottom, the lever moves only 20mm (according to picture it should move 25mm) and it doesnt disengage. How I can get lever to move +5mm longer distance?
Should I route the wire different way in the engine department, or what I could do? Clutch pedal adjustment nut is there under the dash, but if I adjust pedal lower, pedal moves shorter distance and it gives me no help. If I adjust pedal to higher position it moves longer distance, but extra is only "freeplay", and no help from that eather.
Should I be raw, close my eyes and tighten the nut number 19 so tight that clutch starts to disengage properly and after that hope I wont get clutch wreck soon
