New Tracker, Same Old Problem :(
3.3K views 18 replies 10 participants last post by  MutinyGuy
Back in June I purchased the Tracker you see below. It currently has 88,000 miles on it. Besides massive oil leaks and a perforated fuel neck which wreaks of gas after a fill-up everything works perfectly, until now.
About a month ago I took it to the store and after I was done shopping it wouldn't start, not spin and not catch, not sputter, I mean I would turn the key and nothing would happen. The battery is fine, everything turns on, just won't start randomly. I have to open and slam the door multiple times and then it starts. It progressively has gotten worse to the point of it's a 50-50 shot if it will start. Over and over again I have to literally shake the truck to get it to start which it eventually does.
Any local guys have any ideas how to fix this? I doubt it is the starter and if it is I have a brand new which came with the vehicle. I had this same issue with my 98 Tracker before I sold it and now I am stuck with this, no idea how to fix it.
Advice? Local guys looking for some extra cash to help me would be great. The local garages are thieves and I am looking for someone who can help with this, it must be a common problem.
Thank you
If shaking it causes it to sometimes work then maybe you have a bad ground. Check your electrical grounds for a good solid connection and no rust/corrosion. I'm sure someone more knowledged than I can tell you where the points to check are. Or just follow the negative cable and see where it goes.
What transmission is in this - auto or manual?
And when the car does not start (before you start banging the doors) do all your dash lights work with the key on?
When it doesn't start, have you tried jumping the starter with 12v to see if the starter spins.
My bet is on an intermittent wiring problem.....some insulation missing on a wire somewhere, and shorting out on the metal of the car.
#15 ·
Welp it is time -
time to replace this starter unless you enjoy banging it or know how to fix this one.
#17 ·
STRANGE UPDATE!!!! 01/30/2014.
So I've been dealing with intermittent starting for a couple of months now. Simply slamming the door to get it to start and it works about 80% of the time or makes me wait another 5 mins to get it started. It's been extremely cold here in the North East so I've noticed that even when it does start it really struggles. One day it would try to start after slamming my door but was like a dead battery. I got a quick jump from a good Samaritan and I made it home. i disconnected the battery, charged it with my charger over night, hooked everything back up, now it starts every time, without fail, very fast and no issues what so ever.
I am so confused as I had the battery tested before and it was fine, but it slowly died this past month, maybe the battery terminal connectors got loose? I will add those little caps to make the battery grab better to the terminals as I have to tighten the caps all the way just to get a decent grip. I hope it isn't my alternator.
So fixed for now, no more door slamming. And BTW this things rules in the snow, even in 2wd, it just laughs and plods on.
#18 ·
... It's been extremely cold here in the North East so I've noticed that even when it does start it really struggles. ...
Cold weather really has a negative effect on car batteries. Batteries also have a service life of as little as three years. Deep discharging a battery (by leaving your lights on, or something like that) will cause the battery to last even less. Some cars are just hard on the battery. Granted, in my experience, TracKicks are fairly easy on batteries and should last around 5 years.
How old is your battery and do you have any idea of the batteries quality?
If your charging system is up to snuff, you should consider replacing your battery for reliability.
