Low Speed Whine
3.3K views 7 replies 4 participants last post by  pakp123
My 07 GV has 20,000 miles on it.
It has started making a whine noise at low speed that sounds like the drivetrain. It usually goes away once it shifts at around 30MPH. It seems that it only happens after it has run a long trip (several hours).
I checked the tranny fluid and it is full and clean.
I am thinking that maybe it is some type of engine noise, but have no idea what.
Any suggestions ?
Thanks.
#2 ·
Can you replicate the noise standing still and revving the engine? If so, maybe a power steering pump or other accessory with bearings going bad.
Auto trans I assume.
At speed, put the trans in neutral and idle the engine. Any noise then? If noise at this point, I'd suspect something other than engine or trans. Did you do the 1st recommended differential gear oil change at 7,500? :huh:
Low speed whine
Do not hear it in neutral with engine at idle.
Do hear a noise that is similiar when reving engine in neutral.
Yes I can hear it if I put it in neutral while driving slow with engine reved...not sure about if I let it idle while driving.
Yes auto tranny.
I had the gear oil changed at 6,000 and had the levels checked last service; it has 20,000 on it now.
