Status
Not open for further replies.
21 - 40 of 51 Posts
Hi Sir Malerikula.. I'd like to ask if you are able to generate a 4 digit pin code using the vin number?
Unit: Suzuki APV GLX 2015
It doesn't give the option to show a 20-digit ID code.
A decent Bi-directional scanner will have the capability of extracting the 4 digit code, I have used my XTool D8BT also my ThinkTool Pro..
Save
Apparently all users in this thread have a dirty scanner.
I just bought a Thinkscan Plus S7, I thought it was enough for me to duplicate my keys :) Using a locksmith is pretty expensive, so I might end up getting a bi-directional scanner, or if I can rent one, much better..
I might buy the LAUNCH X431 CRP919E Elite OBD2 Scanner, hopefully, it can do what I need. I need to do some research first though.
The cost of the bidirectional scanner is 10x the cost to have a locksmith duplicate a key, so if you can use it 3 times, I believe it would justify buying the scanner.
Thank you @aquanaut20 and @Malerikula for your insights.
I find, contacting the scanner dealer first and inquiring as to whether the tool will perform the required task is recommended
Reactions: impeldown
Save
Hi @Malerikula Am trying to add key (push button) to a Suzuki swift japan 2010. I had read the ID code but when I put it, it says wrong password
please help me this is the read id:
FABD50DC1B6C04FA022A
8 Digit 1,2,3 1E71217E, 32ED0119, 021BF8C9
(Wrong password)
Thank you in advance!
21 - 40 of 51 Posts
Status
