21 - 27 of 27 Posts
Actually it will have an effect. If you get 170 PSI at sea level then, using your figures, you would expect 141.4 PSI at 5000 ft.
No, you are discounting the pump action...
.... Philip
Discussion starter · #22 ·
I'm sorry, but that's incorrect.
A crude scale is as follows
Altitude Factor
1000 .9711
2000 .9428
3000 .9151
4000 .8881
5000 .8617
6000 .8359
7000 .8106
8000 .7860
While the pressure may be 'the same', the air compressor (engine cylinder) has a maximum it is capable of attaining. That maximum (170 psi) changes with atmosphere.
So the scuba tank compressor has a much higher maximum. It can achieve the needed pressure easily, and does so at sea level. It does so less easily at higher elevation, so it takes longer, where as a weaker compressor taps out.
Discussion starter · #23 ·
Regardless...still working on the issue. The crank gear did not slip / the woodruff key didn't shear. I put it back together and torqued to 94 ft lbs.
Still looking for the valve lash check procedure so I don't have to use the Haynes manual.
Discussion starter · #24 ·
OK, found valve adjustment procedure. Valves were a bit tight, but probably within range I suppose. Adjusted, redid compression test, no substantial changes. :(
Just to confirm, lash on all should be .006 on a cold engine....???
I know this is elementary, but double check your spark plug wires are on the correct order. I got a tracker dirt cheap cuz the PO couldn't figure out his sluggish issue; he put the spark wires on in the wrong order.
ANY SOLUTIONS TO THIS PROBLEM?
As I am battling the same problem.
Checked, checked, and rechecked everything. All seems to be installed and adjusted correctly, but engine still runs rough at idle, and is sluggish.
21 - 27 of 27 Posts
