Fusebox
380 views 7 replies 4 participants last post by  Rufus Ridgeback
I have a 2015 Suzuki SX-4 S-Cross Does anyone have any idea which of the fuses under the dash are only live when the ignition is set to Accessory, or ignition on? All the fuses I've checked are permanently live.
There isn't anything wrong.
I want to add some accessories, sat nav with Google Maps because it updates automatically at no cost, a rear view camera, and a phone charging cable. The fitted accessory socket under the dash is rather crowded. I want to hard wire another acc. socket beside the fuse box and wired into it using a piggyback cable. All of the fuses I've tried are permanently live. I want something that turns off with the ignition.
#4 ·
I don’t have the wiring diagram for your car, but the fuse box diagram and assigned fuses are located in this video, which should hopefully help. This way you can test to see which components work with the key off, accessory or running position.
