21 - 29 of 29 Posts
Yeah, it's a pretty good idea to disconnect the battery anytime you are messing around with the wiring in general. Glad you brought it up.
randy
Job Done
The voltage test yielded no results, so I decided to solder the wires in place. I stripped down a little of the stumpy bits and applied some flux, then a little tin solder. I then connected the brown and the whte wires from the central locking, to the corresponding wires on the Alarm. Nothing happened, then I realised I forgot to ground it. Once I connected the ground wire, it all worked as I hoped. Amazing!
I did take some photos of the soldered wires, but they saved on the internal memory of the camera, not the SD card, so I have to hunt out the cable to connect it to the computer before I can post them here.
That's good news. So your next step is to actually hook up the repaired wires to the lock module or is that done too?
Congratulations.
randy
Central Locking Working Perfect
What a job, I'm so impressed I was able to complete it, and Randy I don't think I could have done it without your help.
It was a bit ackward to solder the wires, and I guess that's why they don't look so tidy. When I soldered the wires I just put some insulating tape round them to prevent them from touching, and ended it with a cable tie to hold them tight.
The only thing I didn't do was to insert an inline fuse to the Gnd wire. Do you think I need to do that? I don't wan't it to blow?
I am using only the alarm fob now, and the doors open when I dis-arm the alarm and the doors lock when I arm the alarm. I am so happy.
Hi DeckerZ,
Hey that is fantastic. Really glad you could accomplish the project.
I would definitely get that fuse installed. Its protection that the original design calls for so you don't want to fore go that. You can get them at places like radio shack.
Again, great job DeckerZ,
randy
Job Done!
That's the complete job done, I fitted the inline fuse yesterday, yea Easter Sunday, it's one of the only work free days! Here is a photo of the wires I soldered to the wee stumpy wires on the Alarm Block.
Thanks again randy for all your help, your really helped me big time on this one.
Light Flash
Hello i am in the process of fitting a remote locking kit to my 94 Vitara and am wandering if anyone could help me locate where i would connect the wire that makes the hazard light flash on lock/unlock?
Thanks James
Light Flash
Thanks James
Do you found out yet? I have exactly the smae problem, i know i need green and purple wire but there are a shitton of them everywhere,
21 - 29 of 29 Posts
