21 - 26 of 26 Posts
No.....if it isn't charging then the jump packs being expected to provide running current if about 25 amps at idle. That will smoke and then you have the possibility of severe electronic damage as well.
No need to use jump pack , ordinary battery all that is required 👍
And where are you keeping that connected when driving home? Theres nowhere under the bonnet.
Sorry none of this has helped my problems EPS,ABS,Airbags and battery lights are on also hard sterring when I jump start it no lights come in till I start driving it
You have an electrical issue, the battery is not charged and the alternator may not have the capacity to maintain the demand.. you may also have major voltage drops (poor connections).
A thorough diagnostics of the charge and storage is required before the issue can be rectified..
21 - 26 of 26 Posts
