engine prob more help please :)
1.8K views 4 replies 3 participants last post by  brad03
ok this will be last question i promise :) so i was driving along and all of a sudden my engine cuts out and i roll to a stop it wouldnt start strait away but when it did i kept going then it happened again not untill i stoped for a few minutes did it go again its a 1997 sierra soft top btw i have no idea whats up with this can anyone help me out thank you
#2 ·
Bring the questions ON!
It's either lack of fuel or fire! ;)
Need more info (recent maintenance performed, mileage, detailed experience info, etc). Could be the fuel pump or filter, wiring malfuncton, or .........
#4 ·
This might not be an issue in 1997 model sierras but it is in mine ('96 Sierra). If it cut out when you took your foot off the accelerator and had the clutch disengaged (IE; changing gears) I'll bet that its a spark plug or it's cord has worked itself loose and isn't firing. It's happened twice in the life of my car and I'd expect a recent service would prevent this, but everyone makes mistakes, even car mechanics.
I have had my car cut out 4x4ing though and I had to let it sit for about 15 mins and had to roll downhill to get it to keepo running, it wouldn't run unless teh clutch was engaged forcing it to keep turning over. But it stopped being a pain once I made sure all the plugs were pushed in and drove for a while on the road. Just an idea though.
#5 ·
thanks guys i think i have fixed it the petrol tank was presurising ALOT when you would open it it had a lot of presure in there i made sure i opened it every time i used it for a while and it wasnt stalling anymore and now i have drilled a small hole in the cap it hasnt done it since :) thanks again
