21 - 25 of 25 Posts
I take it they've been "easy" kilometres? It will be interesting to see if you notice much power difference.
(You should try to find proper XL-7 diffs as well- they've got lower gearing and should get it moving off the line quickly!)
Still going well
The H27A is still going well and loves the premium fuel with a little added timing.
Still looking for a exhaust system so far a good one off is going to cost round $2000.00.
Not sure if a LHD will work as the steering shaft will be in the way on one side.
Cheers
Steve
Hi the headers look ok from outdoor auto but the header pipes are not matched length, all good for fitting in place of stock manifolds but for best tune they should be the same length.
Outdoor auto as made the parts to replace each part of the stock system so you can replace each part at different times, not a complete setup.
Cheers
Steve
21 - 25 of 25 Posts
