Since I've owned my 2002 , Rwd, 2-Door, Tracker, the shift indicator didn't line up. For example, when in drive, instead of indicating D, it would indicate 2. I ordered some shifter cable bushings , and installed them today . They were easy to install and work great. I used the same bushings for the top end, up by the shift lever, as well as the bottom end, down by the transmission. I did my research and these are the ones that I used. 5Pc Replace Automatic Transmision Shift Shifter Cable Bushing For Hyundai Accent | eBay
I hope this helps someone.
