Check esp system/ clean parking sensors/ service parking sensors
1 reading
43K views 17 replies 8 participants last post by  Mcube95
My car was fine, it got washed and later in the even i went to start it, ( ibhave the push start suzuki vitara glx 2018) it wouldnt start but it says place fob on start, once i do so the ignition turns on and the car starts beeping and displays a message clean parking sensors, service parking sensors , service esp.
I clean the sensors with a soft cloth and no change. I know nothing about cars can anyone help?
I have recorded a videonof whatbis going on butnim.notbsure how to post.
Discussion starter · #11 ·
I agree with Philip, water in the system somewhere has shorted something.
if car has been sitting for 24 hours or more, you will need a lot of pressure on the brake pedal to activate the switch to allow it to start. This is a known issue if the vacuum has bled out of the brake booster
I will have the dealer send someone out, i flipped the bonnet and i dont see a drop of water, under there is totally dry. Will keep you guys posted.
Discussion starter · #5 ·
did you use a pressure washer to clean the car?
you have managed to fill the sensors with water somehow and they are failing self test. It may come right after a day or so but this may be a dealer repair.
No he used a regular car sponge. Any ideas on how to atleast get the carvstarted soni can take ut to my dealer?
