I have a 2007 grand vitara , what is the best method to get the oil filter change ? Please share your Experience ! Many thanks .
It depends a lot on what the problem you are having is. It appears a 2010 has either a 2.4l 4 or a 3.2l 6. I have a 2.7l 6 so I am not familar with your engine. Is it getting access or can you get access but turning it is a problem?
Jim
I have a strap wrench made from a strip of rubber belting screwed to a stick. I've had it for decades, works just fine (to adjust the size, I just take out one of the screws and re-insert it at the appropriate point).I am considering creating my own extra long strap wrench which will allow me to extract the old filter. Not sure how I'd get the new one in there, though.
We're talking about using a wrench to get the filter off--yes, installation should be only hand-tight (3/4 turn once the gasket contacts, by the book--but I just go as tight as I can by hand, never a problem for over 3 decades I've been doing this)....you shouldn't be using wrenches on it........hand tight as specified on the filter! I have never had one leak hand tight so long as you prelube the seal.
Oil Pump is a positive displacement pump, therefore doesn't require primingHowever now the car needs to have ignition cranked two times for the engine to start up if its been sitting a while. Or maybe I have never noticed before. Maybe I dont hold the starter on long enough. Who knows. Only had for about 5000km. Not sure whether this is low pressure caused by average anti-drain in the filter or that the oil pump needs priming?
Any thoughts?
G
I have been using the Z608 filter from Ryco for 100,000km and 10 oil changes without a drama. I find the smaller filter easier to get around all the piping etc. Seeing as its used on the F9Q i dont see any dramas.Definately a fun vehicle to change the oil on.
My first try with the Grand Vitara 2010 DDIS 1.9L F9Q Engine was a mission.
Overall it would have been not too bad had the ryco filter I got from super cheap been the correct one. The ryco shop book tells you to get a z608, however comparing to the original "suzuki brand" and online, you actually need a z690. (The z608 is used in other renault's with same engine; its 2/3 the size of the z690)
Good to know. Diesel, glowplug light is always off before cranking. Winter ehOil Pump is a positive displacement pump, therefore doesn't require priming
also oil pressure has no bearing on vehicle start, vehicle will start with no oil
do you have a diesel or petrol?
diesels don't enjoy cold starts (until glow plug light goes out)
petrol can drain back if one-way valve in pump leaks internally, not really an issue
EDIT:
but to stay on thread, when servicing my car, I'm able to stick a suitably long pry bar down through the top and tap the rolled edge to loosen, then slide underneath and remove. Installation is from the bottom and only hand tight
Lucky my driveway is on a slope. Tonight I'll reverse then roll down to ramps in the morning.First of all the sump plug is at the front of the sump, which means using ramps wont empty the entire volume, I realised this too late. G
