Battery light.
264 views 3 replies 4 participants last post by  Bex
My battery light comes in occasionally. I changed the battery, but it still comes on occasionally.
#2 ·
Get your charging system tested. It could be something as simple as a bad connection, right up to a failing alternator
#4 ·
Sadly, as this is an ‘intermittent‘ problem, often when you bring this into a shop to examine, the intermittent issue doesn’t show itself as they would need to check the battery voltage while the engine is running and the battery light is on. How old is the belt on the alternator? A belt that slips occasionally might be something to look at or replace.
